PCM seems powerless
The 2 PCM related fuses underhood are good and supplied with power.
Ive tried 2 different PCM's.
Everything else about the car seems to function.
The car has no transmission in it. I have 2 wires shorted to fake out the neutral switch. (Does the trans have to be in the car??)
I was wondering what part of the harness might I not have hooked up that would cause this. I have 2 pigtails under the dash hooked up coming from the engine harness, was there another??
Thanks for the help.
I want to trace grounds now. Are there any others than the 3 small ones that go on the back of the head?
The battery has one small cable going to the shock tower and a large one going to the frame rail. Its fastened with a bolt holding the strap going to the motor. The 3 small grounds check to be grounded to the battery.
