pick a wide band???
Old Dec 18, 2008 | 11:00 AM
slow98Z's Avatar
Default pick a wide band???
I have EFIlive V2 and was woundering which wide band set up is the best to use in conjuction with it i dont real need a seperate display so which do you guys think is best for me?
Old Dec 18, 2008 | 11:45 AM
SIC LSX's Avatar
i have used a few of them. I like AEM alot! simple to install and sensors last! I think i saw them for $240 on jegs site. Im sure a sponsor on here will price match! Best bang for your buck!
Old Dec 18, 2008 | 02:04 PM
slow98Z's Avatar
well im not really looking for the gauge type i need the one that will work with efilive for data logging any suggestions
Old Dec 18, 2008 | 02:22 PM
koolaid_kid's Avatar
It sounds like you are looking for something like the Innovate LM series. I use the LM-1, but it looks like they have come out with an LM-2 & LM-3 also (I've had mine a while). Just Google it, and you can find a link to reviews as well as their website. It should also interface with your data logger, IIRC.
Old Dec 19, 2008 | 10:57 AM
slow98Z's Avatar
ok i checked it out what about the lc-1
Old Dec 19, 2008 | 12:51 PM
dlove's Avatar
lc1 will give you fits.
get something that you can setup to datalog via a serial cable.
see the efilive forum for more.
Old Dec 20, 2008 | 12:29 AM
SIC LSX's Avatar
AEM wideband you can still hook it up to hptuners and efi live and always have a gauge in the car too
Old Dec 20, 2008 | 12:35 AM
1.8t's Avatar
NGK-AFX w/ NTK sensor
Old Dec 20, 2008 | 08:17 AM
BLK02WS6's Avatar
I agree the LM1 and serial cable is the way to go!! Search on EFILive for how to make up the serial cable. And you can get replacement sensors from the VW dealership for a good price...
SS2win's Avatar
I've run the LC-1 and it stopped working
I'm going with the PLX sm-afr HERE and doing the serial upgrade as described HERE
Old Dec 20, 2008 | 08:20 AM
BLK02WS6's Avatar
But that gives you an analog output - the serial output with the LM1 is way more accurate and doesn't have the grounding issues...
Old Dec 20, 2008 | 08:38 AM
AKAFRED's Avatar
has anyone here tried jaw ? seems like the most inexpensive if you don't need a gauge
Old Dec 20, 2008 | 10:18 PM
DrkPhx's Avatar
I use the LM-1 with a serial cable hooked up to EFILive. It works well, however I do hate the tangled mess from all of the different cables.
Old Dec 21, 2008 | 03:38 PM
Bill Bowling's Avatar
I have been using the LC-1 for years with my EFILive. I did have a controller go bad a year or so ago.
Bill
Old Dec 21, 2008 | 08:11 PM
Derek @ EDO's Avatar
If you dont need a gauge setup I think the PLX SM-AFR unit will be great.
http://www.plxdevices.com/products/sm/afr/
Pricing is 185.00 shipped in the US
With a gauge it is 225.00 Shipped.
https://ls1tech.com/forums/sponsor-g...rchase-26.html
Thanks,
Derek
Old Dec 23, 2008 | 04:33 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
im using a FAST dual wideband. easy to see going down the road though
a little bulky. but super easy to hook up and wire into the efilive.
