Ported Fast 92mm installed
Regarding the TB sanding, I started using 180 grit sandpaper, and that was taking too long, so I bumped it up to 80, then to 50. I eventually very carefully began using a dremel.
Autocrossing today, end of first run the cable came out of the groove again. Moved the retainer to the furthest position so it tightened up the slack. Throttle pedal was now just a little bit lower than the brake pedal. Higher idle so it appears it's pulling on the blade and leting more air in. Not used to the change in pedal location because that ended up being a wild ride. Put back after that and it was better.
So is there a way to add another round hole in the cam, maybe between the two already there to find a happy medium?
