How many misfires at idle?
Monitoring with autotap, while just idling, I'm seeing anywhere from 0-10 misfires on all cylinders pretty consistantly. Is this normal for a larger cam? The specs on the cam are 224/230 581/570 112(old G5).
Thanks
Thanks
Restricted User
Yes, that's normal - so long as the value is low and it is consistent across all cylinders then you don't have a misfire problem.
See this thread for more info:
http://www.efilive.com/forum/viewtopic.php?t=215
