Haltech?
Old Jan 2, 2009 | 10:53 AM
waynehartwig's Avatar
Default Haltech?
Getting ready to put a 5.3l/4l60E out of an 08 Silverado 4x4 into my 04 Jeep Wrangler.
Anyone use the Haltech Engine Management systems before?
Would this be wise on my setup? I do want to keep it smog legal....
I guess I would probably need to convert it back to cable throttle body?
I guess I would probably need a standalone computer for the trans too?
It just seems like this would be a very clean, easy way to control the motor instead of tuning the OEM PCM and modifying the OEM wiring harness to work on the Jeep.
EDIT: just to be clear, it's a complete dropout - so I will have the OEM harness, PCM, DBW peddle, etc...etc...
Old Jan 2, 2009 | 11:48 AM
Frost's Avatar
hard to imagine that can possibly be easier since you already have the engine harness and PCM...
Old Jan 2, 2009 | 12:23 PM
BLKHAWK1's Avatar
X2
Old Jan 2, 2009 | 01:40 PM
1bad lad's Avatar
Originally Posted by BLKHAWK1
X2
x3
Old Jan 2, 2009 | 03:37 PM
Wow! I didn't expect that type of response! I just figured with the Haltech I would have a custom harness and engine management system - Keep in mind I already have to modify the OEM computer and harness to make it work in my application. I can either do it myself or pay someone to do it for me
OEM it is, then
Old Jan 2, 2009 | 11:32 PM
10sec_rx7's Avatar
7 Second Club
i would stay as far away from the haltech as you can...
Old Apr 11, 2009 | 12:01 PM
tweakgames's Avatar
I am converting my rx7 from rotary to an ls1, and I have an e11v2. Is there a specific reason I should not use the standalone to control it?
