EVAP system
Old Jan 10, 2009 | 07:18 PM
Big Bird WS6's Avatar
Default EVAP system
what is the delete process to turn this off?
thanks
Old Jan 11, 2009 | 05:54 AM
Wilde Racing's Avatar
How do I change this text
What tuning software are you/your tuner using?
Old Jan 11, 2009 | 03:26 PM
efi live
Old Jan 11, 2009 | 03:27 PM
and what do i do with the system. just put a breather on the tank? or a line off the tank?
Old Jan 11, 2009 | 05:47 PM
nemss1's Avatar
yup breather
Old Jan 12, 2009 | 01:43 PM
bump for tune answer
Old Jan 14, 2009 | 10:40 AM
bump bump. please
Old Jan 16, 2009 | 03:20 PM
anyone, please , thanks
Old Jan 16, 2009 | 03:32 PM
2xLS1's Avatar
I've never seen anything in any vehicle calibrations that controls the operation of the Evap system. AFAIK, all you can do is remove the parts from it and set the Evap DTC codes to no error reported. Just go through the DTC list and find everything that has Evap in the description.
Old Jan 17, 2009 | 10:58 AM
pdsq98gt's Avatar
Why are you deleting it? Not like it's going to purge under WOT anyway.
Old Jan 20, 2009 | 10:28 AM
^ ^ clean look.
and two ^ ^ . is that it. just delete the codes?
Old Jan 23, 2009 | 12:51 AM
kelp's Avatar
Unplug the purge valve. It won't screw your AFR at those "inoppertune times"
