Has this EVER happend before????HELP
Maybe we altered something while installing the master? I just went out and took a quick look but didnt see anything loose or out of place but I'm going to take a closer look tomorrow night and see what I can find. What master did you go with?
Just took a good long look at it and everything is fine. I did a lot of searching on here and I think the crank position sensor might have something to do with it. If you have replaced or tuned your pcm recently it needs to do a CKP relearn. I've read that it shouldnt cause a missfire however I'm not positive and the details are still kinda fuzzy to me but it was also said that having a rev limiter set higher than stock will cause problems with the CKP relearn procedure, and in my case the only time it cuts out is when I shift above where the stock limiter was at. I don't know how all this ties in together but it's looking more and more like the CKP is the culprit. Hopefully someone with more knowledge on this will chime in.
My friend had an I6 Trailblazer that he had tuned and he had to do the CKP. It was an auto... and an I6... so I don't know if it has any relevance, BUT I do know you can have any GM dealer do it for not too much.
Try seeing if setting the rev limiter back to stock fixes it, if so, there's you're problem. I could understand if the position sensor only works to a certain limit and by passing up 6xxxRPMs (or whatever) it kinda loses track of where the crank is. There again it would throw a CKP-based code... I could debate with myself all day. Hope you find it out!
Kyle
Kyle
Kyle
Kyle
If that were the case we would notice the loss without shifting, and my dyno graph has no significant drop at all. The problem is in fact a random missfire only after a very fast shift above ~6000 I just dont know whats causing it yet.
#39
Did a quick search on torque management and found this >>> https://ls1tech.com/forums/pcm-diagn...nagment+torque
Does fit some of the characteristics...
