sensor codes..
Old Jan 31, 2009 | 02:03 AM
tx3's Avatar
tx3
Default sensor codes..
Hey,
well im throwing 02 sensor codes and i was wondering whats recommended to get done?? i can get a base tune over at the local shop for 200 or so.. or are there any handhelds or a cheap way to drop the codes..
thanks any help greatly appreciated!
Old Jan 31, 2009 | 02:50 AM
nemss1's Avatar
if your o2's are bad, u need to replace them
Old Feb 1, 2009 | 12:54 AM
tx3's Avatar
tx3
i cant just get the codes tuned out.. ?? my rear 02s..?
Old Feb 1, 2009 | 01:12 AM
TA-Swede's Avatar
Well, if it's really the sensors, you can save $160 by getting new sensors (sensors are $40, tune is $200).
However, if it's actually the cats, you've still got warranty on those if you're still using the stock ones.
Old Feb 1, 2009 | 01:22 AM
nemss1's Avatar
ok that clears things up now that u specified rears. yes u can get them tuned out. need to research why your rears went bad because u may have a cat prob
Old Feb 1, 2009 | 07:19 AM
koolaid_kid's Avatar
Do you have rear O2 sensors and they are just throwing codes?
Or did you remove the rear O2 sensors with the custom exhaust?
