maf vs sd tune????
Old Feb 6, 2009 | 09:28 AM
johnster's Avatar
Default maf vs sd tune????
which would be the best way to go on a n/a car, with a big cam and ported 5.3 heads ported 90???? maybe some juice
Old Feb 6, 2009 | 09:36 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Well, if you are looking for max potential and streetablility, I would go with one of the 100mm MAF sensor kits. It will allow for virtually no flow loss and still give you the ability for precise compensation for the changing conditions.
Old Feb 6, 2009 | 10:18 AM
johnster's Avatar
cool thanks any more input?????
Old Feb 6, 2009 | 11:22 AM
RedHardSupra's Avatar
use the search button and the stickies
Old Feb 6, 2009 | 11:39 AM
JonCR96Z's Avatar
If anybody knows the differences, it's RedHardSupra, I would always take his advice.
Old Feb 6, 2009 | 07:31 PM
Mike454SS's Avatar
I say speed density...then you don't need to spend any money on any new sensors...properly tuned speed density compensates as well...most guys don't even realize that their MAF cars are running a speed density/maf combo below 4000 RPM anyways.
I always laugh when a professional says speed density needs to be re-tuned for changing weather...that just means it wasn't tuned correctly in the first place.
Old Feb 7, 2009 | 09:11 AM
ringram's Avatar
Old Feb 7, 2009 | 10:31 AM
b00sted's Avatar
Barometric correction what? Haha.
I can name plenty of flying turbo/blower/naturally aspirated street cars that run awesome with SD.
It really does just come down to the tuner's know how.
Here's an SD turbo car tuned by Bob Kurgan. Spent more time driving his kids around the neighborhood than at the track doing this: http://www.youtube.com/watch?v=Cq4RRTGl0wY
Old Feb 7, 2009 | 09:25 PM
Taubr Unit's Avatar
ill be runnin SD on my boosted 5.3
Old Feb 8, 2009 | 12:01 AM
Mike454SS's Avatar
I guess I should have added...I don't think MAF tuning is a bad thing...if your MAF is there and isn't a restriction...it's a great tool (but using the MAF tables to tune the engine is a bad idea...use the engine tables to tune the engine...the MAF tables are the sensors calibration)...I just see it from the other side of the table though, you (in your NA car) already have the MAP sensor, GM installed it...they also installed every other sensor you need and gave your a very powerful PCM that can model airflow, temp correction and a variety of other things VERY VERY well without the MAF. So IF your existing MAF is a restriction...get it out of there, and tune without it...no need to spend money on something else.
For what it's worth, I run closed loop speed density on my NA car...and on my other car (that I'm still building) I will run closed loop speed density as well...only difference there is it will be 2 or 3 bar (not sure how much boost it will see)...so I'll have to buy a new sensor...but a 2 or 3 bar MAP costs a LOT LESS than some crazy MAF that can measure the airflow from a serious forced induction setup...and then when you get into the electronic trickery and whatnot that guys have to get into for very high airflow through MAF setups...just adds cost and adds stuff that can break...and then when you have a tune based on your MAF tables (because as I said...most people tuning with the MAF are NOT properly tuning the car)...and your expensive aftermarket MAF fails...you're screwed.
Old Feb 8, 2009 | 07:46 AM
BLK02WS6's Avatar
I ran my 408 in SOLSD with an EFILive COS and it idled just fine with a Texas Speed "Giant" cam. I drove it on the street all of the time and it was great even in traffic. If you are running a big cam with lots of overlap, MAFless will be a little better in my opinion as far as idle and streetability...
Old Feb 8, 2009 | 11:00 AM
johnster's Avatar
this is very good n fo thanks guys
Old Feb 8, 2009 | 11:05 AM
johnster's Avatar
so a sd tune can handle weather change??? iv heard that with a sd tune the car can lean out and not run rite, when the weather changes
Old Feb 8, 2009 | 02:44 PM
ringram's Avatar
MAF maxes out at 512g/sec so there is an inherent limitation with it and the OEM ECU which doesnt exist with Speed Density.
johnster dude, take a look at the intake charge blending tables, if it doent run right, its because its not tuned properly. 2M+ Hemi's cant be wrong.
Old Feb 8, 2009 | 04:48 PM
johnster's Avatar
ok ok ok
Old Feb 8, 2009 | 05:39 PM
redtail2426's Avatar
i am running a SD tune and it runs perfect all the time.I have a wideband gauge and the only thing that i dont like is if the temp outside gets down in the 40's or 50's it will run rich at WOT.Thats it though the rest of the time it is spot on and the throttle response is impressive.Dont have to worry about any maf restricting the engines breathing.If you have a good tuner who will give your car a good SD tune then do it.
Old Feb 8, 2009 | 11:26 PM
Mike454SS's Avatar
Just means it's not tuned properly if it can't handle changing weather. GM used speed density on L98's for a long time too...it was older speed density, but it worked out great...the first LT1's too (in 92 and 93).
If you upgrade your PCM (looking at your signature, you have a 2000) to a 2001 or 2002 OS there is a PE/IAT table that you can use to correct your PE fueling a bit easier when the intake charge is colder. The 2002 has a few more things that the 2001 OS doesn't have...they probably don't matter, but it's all a wash anyways as you can run any 1999-2002 os in any 1999-2002 F-Body LS1 PCM.
Old Feb 9, 2009 | 08:49 PM
joecar's Avatar
If you look at the units of the "VE" table you will see that they are: g*K/kPa
In other words, the "VE" table is normalized for intake charge temperature and pressure...
Intake charge temperature is absolute temperature computed from a blend of ECT and IAT.
Pressure is absolute pressure.
The gas law says: PV = nRT = (m/M)RT where R is the Universal Gas Constant, n is mole count (proportional to cylinder airmass), M is molar mass (constant), m is the cylinder airmass, V is cylinder volume, P is intake charge pressure, T is intake charge temperature (the steady state conditions of the air in the cylinder before it was compressed in a very short time).
If you rearrange that, you see that that "normalized" airmass mT/P = VM/R which depends only on volume (since M and R are constant).
The PCM takes pressure and temperature into account.
If SD doesn't work right, then something else is incorrect or is being modeled wrong.
