idle problem 02 camaro
It could also be fueling if you O2s are bad. Obviously it is an issue when the ECM is not controlling the idle and/or fueling (open loop).
I bet when you restart your car you are seeing high IAT and this can make you run a little lean for a few seconds after restarting.
O2 codes are a fact of life with LT headers.
and to go with all this my asr off light comes on and off ever seens the cam install but no code for IAC,TPS or MAF i think seens the cam it has a mind of its own!
thanks
really messing up the open loop mixture. Changing the
"charge temp bias" table and relocating the IAT sensor
seem to both help this behavior, from what I've seen
on the 'boards. But I have never messed with that,
only with getting the idle mixture generally right (which
also helps it). It seems to me like the thing is probably
over-enriched, which happens a lot with a big cam and
a VE table that isn't fitted up to it at the low end.
DTC P1133 HO2S Insufficient Switching Bank 1 Sensor 1
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
If you have LT headers these 2 are common, if not you need new O2`s.
1. You're VE/MAF #'s are off which causes the PCM calculations for the MAP to be off as a result. Properly tuning the VE/MAF after a "large" cam swap reportedly fixes quite a few cases of P0106.
2. There is "a table" which you can adjust to decrease the PCM's sensitivity to the MAP fluctuations due to the overlap which many larger cams have. While this seems like the easy way out, I'm guessing you're not doing yourself any favors here. If such a table DID exist, I'd love to know which it is to confirm it can be done and try to research what adverse effects adjusting it might have on a tune.
Any one?
I'm getting the p0107 MAP Low Input and 2 P0133 insufficient switching codes. Same idle surging/wanting to die and occasionally hanging. Also have LT's.
Did any of you guys figure out what the fix was? I believe its tune related, but the tuner is telling me its not. I went to a different tuner and they said maybe, but the codes should generally not be there and they'd rather tune without them which is putting me in this vicious circle of is it the shitty tune, or something sensor/mechanical related.
Any help is greatly appreciated!!! Thanks!
