strange diablo predator question
Basically, I want to know if I will have full control over the rev limiter because I want to lower the rev limiter way down while the camaro is at the body shop getting painted.
Thanks in advance,
Colin
Thanks in advance,
Colin
Only additional thought I have to pass on is that if I knew then where I would be now with building my car, I would have bought EFI Live. Although my car run very well, there are numerous fine, fine tuning details that are not realistic to handle with remote tuning. AFR, shift points, spark etc are spot on but fine tuning thing like TCC lock/unlock need in car logging/tuning.
People who bad mouth the Predator and its ability to be used through a CMR are uninformed. For mild to intermediate tuning, it is a great way to go. Advanced tuning is a bit different but not all people need it..
If you need more adjustment than that, there is a way around it, lemme know.
Also, if you need it, I can write you a simple tune for the rev limit set however you'd like it, and you can load it to the Predator.
Thanks
Mike
