I have a "reverse" question...............
Old Feb 17, 2009 | 05:27 PM
LS6427's Avatar
Default I have a "reverse" question...............
I've looked through the lists of codes that the PCM will pop up when there's an issue. I can't find what I'm looking for and I'm sure alot of you know right off the top of your heads.
If the MAF fails completely.....what code number is that?
I see 101, 102, 103 codes, ....but is there one for a 100% FAILED MAF?
Old Feb 18, 2009 | 01:16 PM
Bad Blue WS6's Avatar
are you unable to get your car in reverse? did you get 803 and 102 (PO) codes?
Old Feb 18, 2009 | 04:01 PM
LS6427's Avatar
No, no problems other than low power throughout rpm range and stumbling while taking off from stop and while accelerating from a rolling steady speed.
P1153.......Insufficient Switching Bank 2 Sensor 1
Bad 02 sensor, right? But which side is that? My rears are deleted.
Old Feb 18, 2009 | 04:30 PM
2001NBMZ28's Avatar
Bank 2 is passenger side.
Old Feb 18, 2009 | 04:31 PM
LS6427's Avatar
Guess I should just buy 2 new ones. These two are like 5 years old on my 427ci. Wonder if the other one is gonna take a **** soon too.
Old Feb 21, 2009 | 01:19 PM
TAQuickness's Avatar
Depends on how the MAF fails as to which code you will get. Any one of the 3 means the MAF is failed and the PCM is running in SD.
Old Feb 21, 2009 | 11:03 PM
crispytoast's Avatar
a few weeks ago my car was ideling at about 400 (and really rough) when rolling to a stop but was fine at idle. I didn't even have any codes but all was well when I changed the maf.....Not really sure if that helps you but I thought it may be relevant.
