Synergy 2 step question
I'd like to sell it because I'm lazy and don't want to hunt down the wires to tap into. But if I don't sell it then I'll have to get un lazy
Is the brake light switch under the dash? Where about is it under there? Once it's installed, you just have arm, place foot on the brake, and put the pedal to the floor and its stuttering and the rpm set, and then just let go of the brake and you're on your way or what?
Also where did you splice them into at? I was thinking at the coil connectors themselves, but those do not match up to all of the colors either, 1,3, and 5 do, but 7's not the same as listed. Any insight would be great
