TPS Woes
I have checked the TPS and...
I have a solid verified ground...
I show .58V at idle position...
I see a smooth progression with the throttle sweep...
I show 4.5V at WOT...
Unless Im mistaken this shows that my TPS is fine?
Any advice on where to look next?.. Possibly related to the MAF code?...
http://gearchatter.com/viewforum34.p...71e51a3b460f07
Well I just probed the MAF a minute ago with key on and..
I show a verified ground
I show 11.5V at the pink wire (11.99 at the battery)..I assume the .5V loss is normal?...
I dont know what I am looking for with the yellow wire but it shows 4.97V
Anymore advice?..
Guess I need to find a 98 Pin diagram and check for cont...
Same deal for MAF I assume? I just posted about my MAF issue as well...
When tapped into the MAF 5V Reference
-Idle= 4.3V
-Part Throttle= 3.6V (fluctuated depending % throttle)
-WOT=2.5V
There was NO random fluctuation...if I drove around light throttle it would steady stay 4.0V or above...as soon as I rolled into it I would see a drop and see anywhere in the mid to high 3V...WOT always dropped into 2.5-2.75 territory...It was certainly correspondent to throttle position...I could control it with the pedal.
When tapped into the TPS 5V Reference
-Idle= 5.0-5.01V
-Part Throttle= 5.02-5.04V
-WOT=5.08V
Unlike the MAF findings...the TPS NEVER dropped below 5.0V...and in fact when given throttle it slightly increased...
So I pulled the air pump relay and fuse, and it looks like now that a few ignition cycles have occured, I only have air pump codes now..no more P0102 or P0121 ... Keeping my fingers crossed that it stays off.
