HP tuners questions
I figure as long as it has a good vaccum manifold for adequate signal, and a GM TPS sensor I think it'll work. What can any aftermarket ecu do that a flashed stock ecu can't?
Some aftermarket ECUs let you run in Alpha-N mode (rpm vs. throttle position).
I'd prefer not to use alpha N, I can't imagine a car that would run worse than that. When I was in FSAE we ran our car with just MAP and RPM and it was the least responsive piece of crap i've ever messed with. It worked but not all that great.
Thanks for the advice and replys, I think I'll just try it and hope for the best.
I'm NOT sure if the 2-bar OS has that table added also...but if you're running boost why bother with ITB's? Then you will need a plenum or plenums above the TB's rather than seperate filters...I think it could be a very unique/cool setup...but usually I think of ITB's on an NA setup.
