to much fuel? hpt?
You're definitely running too rich regardless of all the other info in this thread. You need to slow down a bit and take a step back. Read a bit and start working on getting your scanner setup for AFR % error and then get your VE dialed in. Next you'll need to work on your MAF. THEN you can start to tinker with PE and timing and whatever all else you'll need to get your AFR corrected on the juice.
Rest assured, you're leaving a TON of power on the table running that AFR on the spray. Take your time and get this right and you'll see what I mean!
you get them the same by tuning the injectors/ve / maf tables correctly. The PE enrichment add is based off 14.7:1 so if you're tables are off going into PE then your a/f will be off. Are you trims locking in at 0?
