converter locking in 2nd & 3rd @ WOT...EFILive
Old Feb 26, 2009 | 01:13 PM
Superado's Avatar
11 Second Truck Club
Ed...e-mail sent
thanks!
Old Feb 26, 2009 | 02:16 PM
Ed Wright's Avatar
9-Second Club
Originally Posted by Superado
Ed...e-mail sent
thanks!
Nothing recieved here yet.
Old Feb 26, 2009 | 02:21 PM
Superado's Avatar
pm sent
Old Feb 26, 2009 | 04:09 PM
Superado's Avatar
Thanks Ed!
cablebandit's Avatar
Thanks for the info Ed. Is this a prob in the OS or the trans calibration section that we cant access?
Old Feb 26, 2009 | 07:48 PM
Ed Wright's Avatar
9-Second Club
Originally Posted by 2xLS1
Not in the Gen 3 cals. Only the older Vortec cals have it.
I looked at a "stock" definition file, it definitely is there. TC has it as two tables (I changed mine to one 2X3 table). The tables in Tunercat are under Transmission Tables, and are labeled "TCC release Speed Vs Gear" and "TCC Apply Speed Vs Gear". No matter what the conditions are the TCC will lock or unlock at the speeds listed in those tables. Most other tuners I talk to call it WOT because the TCC will be locked anyway before the MPH listed there if not WOT. It's difficult to tell if/when a stock TC locks at those speeds, a loose converter shows it right up.
Old Feb 26, 2009 | 07:51 PM
Ed Wright's Avatar
9-Second Club
In the transmission calibration file, or "segment" as some call it. You can access it if your tuning software has it. Nothing secret about it. Only 2000 & older calibrations use that table. I have not found it in an '01 or newer cal.
Old Feb 26, 2009 | 11:26 PM
dlt76028's Avatar
12 Second Truck Club
i wonder if this is something that could help my converter lock? i cant get it to lock on the highway at all?
Old Mar 5, 2009 | 09:39 PM
Wilde Racing's Avatar
How do I change this text
Are you talking about locking @ WOT? There is a seperate table for WOT TCC lock & unlock until 2001. Many truck cals are set to lock @ 75 MPH when WOT. I don't see that table in either EFILive or HPTuners. You often can't feel it lock then with a stock converter.
What trucks are affected? because I have no issues keeping mine unlocked well above 75 mph. I also use HPTuners,and a 02 PCM..
Old Mar 6, 2009 | 09:13 AM
Ed Wright's Avatar
9-Second Club
I believe if you go back and read what I posted, 2001 and later models do not have a seperate table for that.
Old Mar 6, 2009 | 09:22 AM
So it is only a issue with the 99-00 pcms truck then?
Old Mar 6, 2009 | 09:38 AM
  #32
Ed Wright's Avatar
9-Second Club
As I mentioned before, 1987 through 2000. 2001 and later trucks is all in the normal TCC lock & release tables. You change those at the higher throttle angles. Very simple.
Old Mar 21, 2009 | 11:31 PM
  #33
Superado's Avatar
well...
I used the new adjusted tune after completing segment swaps of each section...
still locks in 2nd and 3rd...
going to try it again with segment swaps on everything EXCEPT transmission sections...then copy & paste on transmission tables...
If that doesn't work...then I'll try it w/o segment swaps and doing table by table conversions...
we'll see...
Old Mar 23, 2009 | 10:17 AM
  #34
Ed Wright's Avatar
9-Second Club
You did raise the MPH in the normal, performance hot an cruise apply and release tables at high TPS, didn't you? I didn't do that part for you. I only did the table to which you did not have access.
Old Mar 23, 2009 | 08:17 PM
  #35
slow67's Avatar
Gingervitis Addict
Can anyone help me out with this issue? I have HPTuners. Mine is a 2000 F body PCM with a 4L80 segment swap.
Old Apr 21, 2009 | 09:29 PM
  #36
Superado's Avatar
more on this subject...thanks slow67...
backs up Ed's comments
http://www.hptuners.com/forum/showthread.php?t=22730
