wot shift rpm vs wot shift speed tables
i thought if you had the mph tables set lower than the actual mph that the car shifts at then these tables won't have much of an effect anyways. i think if you do this than you can use the rpm table for your desired shift points. someone else better verify this because i am not 100% sure....
Set the WOT upshift mph values super low and set the rpms to your desired shift points. Make sure to set the WOT downshift mph values lower than the upshift WOT mph values. This works perfect for me.
