Can i use low inpadence injectors with factory PCM?
Old 03-21-2009, 12:06 AM
fastsspr's Avatar
Default Can i use low inpadence injectors with factory PCM?
I have 55 lbs injectors but they are low impedence.Can i use them on a car with a factory computer? Which is the difference from low impedence to high impedence injectors? Thanks for the help.
Old 03-21-2009, 02:08 AM
dewey04's Avatar
You can use them by either wiring in resistors on to the wiring of each injector or by using an injector driver box a few company's make them.
