Vinci Handheld Programmer
Old Apr 4, 2009 | 04:01 PM
corvet786c's Avatar
Default Vinci Handheld Programmer
What do You guys think of This Handheld?
http://www.vincihiperformance.com/fbodyls1.html
Old Apr 4, 2009 | 10:00 PM
mrr23's Avatar
very good. i used to use it on the wife's car when it had heads and cam. here's a writeup i did on it
http://www.stealthram.com/vhptuner.htm
Old Apr 10, 2009 | 08:24 AM
SJC5's Avatar
Robert,
You are the recognized expert on the VHP Tuner so I would like your advice.
My vehicle is a stock 04 Corvette A4 Coupe with a Blackwing intake and Magnaflow catback.
I am currently using these settings with my tuner:
Cooling Fan = 190 deg.
Fuel Enrichment = 0
Spark Curve = 0
Engine Tune = CAM #1
Trans Shift = Performance
Trans Firmness = Performance
It seems to run very strong but I get a little engine knock for a couple of seconds at WOT. Is it recommended that I use +10 Fuel Enrichment to eliminate that knock or a entirely different setting?
Thanks,
Steve
Old Apr 10, 2009 | 01:01 PM
mrr23's Avatar
you can try that to see if it removes the knock. if it doesn't then reduce the spark curve 10%.
i see you're using cam #1 with a stock cam. does it run better using cam #1 versus using hi perf/stock cam?
Old Apr 10, 2009 | 01:36 PM
SJC5's Avatar
Thanks for your quick reply!!!
I'm using Cam #1 because it was recommended to me by another forum member and he stated that he had used that setting and confirmed with Vinci.
I've used Hi Perf/Stock Cam with both Spark Curve & Fuel Enrichment at +10 and it knocked slightly as well but pulled pretty hard. I then used Hi Perf/Stock Cam by itself and no knocking but now I'm experimenting trying to find the best results. I'm hoping you can steer me the right direction with your experience and me avoiding doing some damage to my car with settings I shouldn't try.
Thanks
Old May 16, 2010 | 10:11 PM
StangKilla's Avatar
i know this is an old thread but I have had one in my 2000 Z28 cause i changes the gears and needed it. I thought it was awesome tho, not too sure about performance wise but it was really fun to tinker with and if you had a Crane cam im sure it would be amazing.
any way my car was recently totaled and long story short need to sell mine. its in returned to stock like new condition. please help a fellow fbody enthusiast down on his luck and if you know anyone who "needs" one please pass along the word
my email is matthew.raducha@knight.ucf.edu
Thanks Guys!
Old May 19, 2010 | 08:37 AM
corvet786c's Avatar
I am glad I dont have that programmer anymore, when I got my car hp tuned I gained 20 rwhp and Joe Vinci said it was close enough to hp tuner I think not.
Old May 19, 2010 | 07:50 PM
corvet786c's Avatar
I would'nt buy vinci/crane products ever again!!
