RICH RICH idle and cruise HELP
I am currently running a t70 at 6 psi. Lucas 42 lb injectors. I need some help figuring out why its idleing at 11.5 and cruising at 10.50. I did all the steps on the hp tuners demo and this is what I ended up with. This is a open loop tune sd. If anyone can take a look and give me pointers on what tables to look at, I would really appreciate it.
I also cannot seem to get me scanner config to do the afr error so I can use the auto tune. Does this feature work logging AFR into the egr port?
Here are the files
Here are the files
Ok, you're definitely doing it wrong. Do you have the PRO or standard version of HPTuners?
Have you tried using the default imperial config and just adding what you need and subtracting what you dont need? You're not logging everything you need for the AFR error % to work.
i have the standard version on hp tuners. i guess ill have to find all the stuff i need to scan to read the afr error and then see if i can get it to work. i havent messed around with this hp tuners much at all. just trying to get the idel down and cruise down for now.
