Please Helo.. EFI Live-Adding Wideband PID
Hello,
I am a total newb at using my EFI Live V1. I really like it but I am struggling with both enabling and calibrating my NGK AFX wideband.
I have the external plug wired correctly and actually had it displaying on the dashboard gauge for a while but I noticed that the dashboard gauge seemed to always read 14.63:1 unless I went WOT, then it read 12.12:1.
I really, really need someone to look at my list of "selected" PIDs and the sae_generic file I copied for this post. I also attached the voltage/afr table that works with my NGK wideband.
I read and read the instructions but it seems that it just won't click for me. I did good with my TCC, rev limiter, shift point tuning. I just CANNOT get this done.
If someone could walk me through it with examples of the changes, I know I can get a grip.
Thank you very much!!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Go here, they can help you
http://forum.efilive.com/
Yep, got it posted there too. Figured that much out.
http://forum.efilive.com/showthread....highlight=PINs
read this, it can help you,I have the PLX -WB and it hook to my laptop.
You can use this but with your WB. Your WB is in your PINs(F8)
