Is this HP Tuners PID set up correct?
If I use the AC sensor wire will this work?
Or what I really want to do is add a pin to the ECM for the EGR and use that wire to run the wideband signal through. On a 2002 you just add the pin, enable EGR and change to the EGR PID?
Guess no one knows?
I seen the post from hp tuners here and used that to get to this http://forums.corvetteforum.com/c5-s...hp-tuners.html
Just wondering if anyone knew. Anyone know?
Yeah you can run the wideband's output (0-5V) to the AC pressure sensor's PCM input, and yes, that is the how to setup the PID to get it in the ballpark assuming your wideband output is 10-20:1AFR. You may have to do a little correction in the PID if you get an offset (what the wideband shows and what is being logged do not match).
Alright, great. I just got the wideband dropped off today (AEM UEGO). Already did a few runs with it hooked up temporary.
Next I'll work on the permanant installation and then get it set to run with HP Tuners.
Thanks.
Thanks.
