Innovate LM-1 users
Someone tell me this isn't the case. I had gotten a bad sensor from a friend so I could hook the aux to it and be able to use the wb in the stock hole and be easily swappable back to a stock sensor. The high wire is the one autometer gauges are hooked to, so that's where I put the aux wire.
I worked on it some more today, and I think I've got it pretty close. It idles fine anyways.
It seems to update way too fast, or I just need to play with the 'narrowband window' some more. It fluctuates A LOT compared to the pass side sensor, but maintains pretty close to the same average. I had to use both outputs to make it work. I'll have to recheck, but I'm pretty sure I have out1 set as they supply it and hooked it to the high sensor wire. I hooked out2 to the low sensor wire and made it a steady .2v. I can't really test how they relate but I guess maybe the low is a reference or is added/subtracted from the high.
