SES light and car sputters
Old May 6, 2009 | 09:41 AM
NoGo's Avatar
If it still does it in open loop, then we are back to what I suspect is still a lean fueling issue.
Your MAF is the next big contributor to fueling. Try checking it and cleaning it with some MAF cleaner.
If your fuel filter became plugged then you should be able to tell with a fuel pressure gauge on the rail. Hook it up and see if your pressure is 58 psi. Rev the car up and see if it drops more then just a few PSI.
If everything checks out, we may want to start looking at ignition....changing plugs and wires, etc...
Old May 8, 2009 | 03:40 PM
Toadman1's Avatar
I changed back to the stock maf (had a slp on it) and it started sputtering again and the clanking sound is back in the exaust again. Do I need to hook the back two o2s? Also the car seems to idle down eith the front two off; should it still do that?
Old May 8, 2009 | 06:57 PM
Toadman1's Avatar
I also noticed the ticking sound from the right header while the left header is quiet. I'm guessinh whatever wrong is on the right side of the engine.
Old May 10, 2009 | 12:43 AM
Toadman1's Avatar
I was reading elsewhere that it could be a coil pack. Does that sound like a good choice to look at before the plugs?
Old May 11, 2009 | 08:28 AM
NoGo's Avatar
I would gamble that the plugs/wires go before a coil pack.
I would also hook your two O2 sensors up again. Clearly, they aren't the problem.
Do you have a scantool to view engine data. It is getting to that point...
Old May 11, 2009 | 03:01 PM
Toadman1's Avatar
The second plug wire came off on the right side. Its too hot to put on right now but it seems to be the problem and the ticking sound that I was hearing. I'm hoping its the problem since since its an easy fix.
Old May 11, 2009 | 04:20 PM
Toadman1's Avatar
Hooked the plug back in and took it for a spin and wot and ran great and no more missing sound in the exaust. Thanks for helping out with fixing it.
