HELP!! wierd problem with my car tonight.
Old Apr 23, 2009 | 10:57 PM
Darren P's Avatar
Exclamation HELP!! wierd problem with my car tonight.
My car would not start when I went to leave Mooresville tonight, it would fire and die. I had removed the ABS fuse because I am running 28" rear tires and skinny 25" tires on the front and it screws with the ABS computer. I replaced the fuse and the car started up just fine, however I got about a mile down the road and it just died. I placed it in neutral and started it right back up. It did this at least 15 or 20 times on the way home. any ideas on what I can look at?
It seems to only do it at part throttle. It did something similar the first time I ever had it on the dyno with the current setup. At the same speed/throttle position/rpm it would just die. When we floored it, it pulled through and ran just fine. it has not done it since till tonight.
Any ideas are welcomed. Thanks
Old Apr 24, 2009 | 07:57 AM
NoGo's Avatar
Does it sputter and die or just die-die?
Old Apr 24, 2009 | 09:39 AM
98Camarod's Avatar
Good question.
Old Apr 24, 2009 | 01:51 PM
Darren P's Avatar
It just dies like the ignition has been cut off, no sputter or anything, It also will not fire back up unless I first turn the switch off and on first, but then it cranks up like it should.
Old Apr 25, 2009 | 06:48 AM
Darren P's Avatar
Bump
I remember when you could ask a question like this here and get an answer pretty quick
Old Apr 25, 2009 | 07:23 AM
98Camarod's Avatar
Do the gauges flash or go in and out?
Old Apr 25, 2009 | 11:46 AM
Darren P's Avatar
The guages all go off and it dies
Old Apr 27, 2009 | 10:03 AM
NoGo's Avatar
It could be many-many-many things. And when they just die like that it is very tough to find.
Usually, on a problem like this I try and look at what was last changed before the problem started?
New harness? Installed turbo kit? New PCM?
