Possible to delete MAF?
Old May 10, 2009 | 04:59 PM
  #41
macca_779's Avatar
Originally Posted by 98Camarod
I realize its an average, just if that one particular cell is hit the same way due to the lag then you will have large spikes in the VE table when you copy over the afr error % right? BTW I have hptuners, I wish they would incorporate when you playback the log it shows it in the actual tune which cells are being used. That's a real nice feature for sure.
Like I said the lag is not huge and I don't have a problem going WOT and getting accurate data. But like I also mentioned. The Delta TP Filter is there to ignore those quick changes so that the data doesn't get populated in the wrong cell. You also don't have MAP cells show until they hit a set amount of times. That in itself is a very good filter. Hell If you really wanted to be picky you could add a Delta MAP and Delta RPM filter too, but I don't believe its necessary. There is plenty of scope to get as accurate data as you deem in the Scan Tool.. You just have to set it up once and let it do its thing.
