Idle issue after tune
Old Jun 18, 2009 | 09:23 PM
steve40's Avatar
Originally Posted by Slowhawk
The idle problem is probly caused by the PCM opening/shutting the IAC valve suddenly.I've run into this alot on 98-00 cars.Only about 10% of the cars do it for no apparent reason.
i'm experiencing this myself, just when the car is in gear it will idle sometimes, then dies, and usually when you see the iac moving around. i have a 99 pcm. would you recommend flashing the pcm to the 01+ operating system?
Old Jun 28, 2009 | 10:51 AM
SSwolf's Avatar
Default same thing
I am having similar problems. '01 texas speed head and 224 cam swap. When I start it seems fine, but put it in gear and RPM's drop down toward 500, sometimes stalls sometimes recovers. When I go to stop at lights RPMs drop again and sometimes stall sometimes recovers. Doesn't matter how long it sits in idle warming up. It must warm up for a 3-4 minutes before I try to drive it, or I will never make it out of the driveway. After it warms up it needs driven for around 10 miles then the idle tends to get better. When I go to a stop then the RPMs sometimes still drop, but only to 650-700 and recovers.
It kind of sucks to have fuel injection and have to warm it up for 3-5 minutes before it is driven.
Any more advice for us would be great. I don't understand the wideband stuff you guys are talking about. Any threads I should look at?
