Motec MLS - LS1 specific ECU
Anyone use one or have any experience with this LS1 specific Motec? I had an Autronic in my last car and I was amazed with it. Motec seems like the next step up and this one is very very reasonably priced at about $1000.
The compact and lightweight MLS is dedicated to Chevrolet LS1 and Lexus/Toyota V8s, providing a price competitive solution for this range of popular engines.
A derivative of the M4 engine management system, it has all the benefits of performance and reliability associated with this earlier generation ECU.
The DOS-based tuning software is efficient and easy to use with the same functionality as the M4 ECU Manager software.
Engine Tuning Features
*DOS-based ECU Manager tuning software
*Individual cylinder tuning of both fuel delivery and ignition timing
*3D fuel and ignition tables for engine mapping
* Table axis selectable from a range of channels
* Fully configurable axis points on fuel and ignition tables
* Chevrolet engines:
o Ref/Sync modes to cover the old and new trigger patterns for LS series of the modern V8 Chevrolet engines with 8 coils; mode 233 (24 crank teeth) and modes 81 or 83 (2 missing teeth; one per cycle)
o Ignition system needs to be wired and run in group fire mode using the 4 injector drivers with the coils configured as wasted spark (leaving 1 auxiliary output)
* Lexus/Toyota V8 twin distributor style 1UZFE engine:
o Multi-tooth Ref/Sync mode
o The number of coils needs to be clamped to 2 (leaving 3 auxiliary outputs)
Free access to wideband Lambda and data logging for initial tuning for the first 6 hours engine running time
Additional Distinct Features
* Capable of modern control functions, such as:
o Traction control
o Overrun boost enhancement (anti-lag)
o Gear change ignition cut (flat shifts)
o Boost control
o Nitrous injection
* Fully configurable sensor inputs including custom calibrations
* Transmitting data via RS232 bus
* Wideband Lambda measurement capability
* Integrated advanced diagnostics, including injector & crank trigger diagnostics
Data Acquisition
* Internal data logging (512 kB) with download via RS232
* State of the art i2 Standard data analysis software
Upgradable with optional functionality to make additional features available when you want them, activated through a simple password system. http://www.motec.com/mls/mlsoverview/
o Traction control
o Boost control
o Nitrous injection
Data Acquisition
I've looked into them and even poked around in the software. While its capable of doing the job, you can get away with the factory PCM in 99% of applications. The software is very crude compared to EFI LIVE which is a huge turn off.
