moates question
Old May 2, 2009 | 01:59 PM
Tzion_ben_Arthur's Avatar
Default moates question
Does the moates PCM allow a tuner to see the cell the car is operating in and change it on the fly like a DFI or Big Stuff? If so, I am going to get one. I have EFI live right now, and I bet this will reduce some time reflashing the PCM often.
Old May 2, 2009 | 02:14 PM
edcmat-l1's Avatar
Your EFIlive shows the cell your in, in your map. You'll see the same thing with the RR. The only difference is the ability to make changes on the fly.
They have an auto tune feature now that allows you to use the wideband input to automatically tune the VE or MAF tables. I've never used it but have read about it. Sounds pretty slick.
There's plenty of info on their forum.
Old May 2, 2009 | 04:16 PM
I am there dude. Thanks!!
Old May 2, 2009 | 10:19 PM
One more question.. Is this what I want? I have a 2002, using COS3 right now.
http://www.moates.net/product_info.p...roducts_id=105
Old May 2, 2009 | 11:48 PM
shoemike's Avatar
You will also need an EFI Live Realtime License
Old May 3, 2009 | 09:52 AM
Will I still need this if I still have a open license on my FlashScan?
Old May 3, 2009 | 10:03 AM
slow's Avatar
yes, you need that license to talk to the roadrunner, it is different than a vehicle flash license.
Ryan
Old May 3, 2009 | 10:50 AM
Ryan
Thanks
 Michael S. Palmer
Old May 3, 2009 | 12:18 PM
Doc's Avatar
Doc
Well worth it. You will learn a lot with the RR.
Old May 3, 2009 | 02:13 PM
schwoch1's Avatar
I will second that, the ability to change something in real time and see what the effects are going to be helped me greatly figure out what alot of the settings/parameters do!!!
Mike
Old May 6, 2009 | 07:53 PM
Thanks for th help.
Old May 7, 2009 | 08:06 AM
wait4me's Avatar
The reason for the seperate road runner license via efilive, is simply because you can use the road runner on ANY vehicle of that ecm type and so for tuners, it is nice because you get a car, pull out the stock ecm, put in the roadrunner, and then tune. After you are done tuning the customers car, then you pull out the roadrunner, put the stock one back in and flash in your final tune.
It is a huge timesaver. Especially if you use all the autotuning maps we have set up.
Old May 7, 2009 | 08:15 AM
slow's Avatar
agreed, the roadrunner is great, I have 2, 1 98 and 1 99-02 and I've used them in several vehicles.
Ryan
