Scanmaster or Wideband????
Old May 2, 2009 | 03:26 PM
mk1973's Avatar
Default Scanmaster or Wideband????
What would be the best for monitoring things while driving?
I am not going to be using either as a tunning device, but what would be the prefered why to go an why??
any input would be great!
Old May 2, 2009 | 05:50 PM
Mikes96z's Avatar
scanmaster is a narrow band meter, but its a great digital tool. Wideband are more accurate.
Old May 3, 2009 | 12:17 PM
01Z28M6's Avatar
You could use them both. Like Mikes96z said ....
The Scanmaster (the aeroforce interceptor scan gauge is what I would buy now), is simply a nice item to have in your cockpit. The wideband is the brass tacks tuning diagnostic when you're totally serious about a/f metering.
Old May 3, 2009 | 07:27 PM
YellowToy/A's Avatar
A wideband will tell you what ur airfuel ratio is. Is will let you no if you are running lean at full throttle. If you are you should have it tuned. The aeroforce interceptor scan gauge is cool and let you monitor kool stuff.
