rear wheel speed erratic
Old May 2, 2009 | 08:09 PM
MUSTANGBRKR02's Avatar
Question rear wheel speed erratic
After cam install i now have this light and it is causing the service vehicle light.
Anyone have any clues or ideas?
Thanks
Old May 4, 2009 | 02:13 PM
NoGo's Avatar
What is the actual P---- code?
Usually, the most common code after a cam install is P0300 random multiple misfire....which you will need tuning to eliminate.
If you are throwing speed sensor codes after a cam install, then I would say it is unrelated to the cam.....unless you did some other work while the car was down.
Old May 9, 2009 | 03:22 PM
no other work and i will get the code.
Old May 9, 2009 | 03:25 PM
c0237 is the code
Old May 11, 2009 | 08:52 AM
NoGo's Avatar
I don't know why this light would come on after a cam install. Did you flash the PCM with a different OS for the cam tune? MAFless running, something like that?
I'm not very familiar with this code. If it comes form the ABS system (which I think it does) you may want to try cleaning the wheel speed sensors at all 4 points. It isn't uncommon for brake dust and crud to build up on them and goober the signal, or for one to get knocked out of place.
Old May 11, 2009 | 07:04 PM
No new OS, I will try that this weekend wit the connectors. I know it is not common after the cam install but i am clueless on what or where to look...
Old May 22, 2009 | 09:55 PM
Well after fixing the TPS voltage low/high with a new pigtail that light has gone away.
Now i just have the service vehicle light and the 2 loss of communication codes.
