Tuning for wet nitrous question..
The stock tune starts to pull 1 deg of timing at 40c and then it ramps up to 3 deg at 50c. Pick a resistor with the proper resistance; the resistance that the IAT sensor provides at 50c and you will instantly pull timing. Here is the stock IAT sensor resistance chart. If you want to pull more than 3 deg, you will need to modify your IAT Spark Table and pick a resistor accordingly. For mine, I modified my table to pull 6 degrees at 90c and then put a 240ohm resistor in. Then I run the pin 86 on the relay to my NX progressive controller. Works great. If you want to get fancy, you can run a 3 position switch and incorporate two relays... to you can pull timing at two different levels.
This thread has a diagram and a pic of a timing table that shows what I mean.
https://ls1tech.com/forums/nitrous-o...t-how-pic.html
Click here to SEARCH for Resistors
Radio Shack 1/2 Watt Resistors
9420 ohms = 32 *F - 0 *C
7280 ohms = 41 *F - 5 *C
5670 ohms = 50 *F - 10 *C
4450 ohms = 59 *F - 15 *C
3520 ohms = 68 *F - 20 *C
2796 ohms = 77 *F - 25 *C
2238 ohms = 86 *F - 30 *C
1802 ohms = 95 *F - 35 *C
1459 ohms = 104 *F - 40 *C
1188 ohms = 113 *F - 45 *C
973 ohms = 122 *F - 50 *C
667 ohms = 140 *F - 60 *C
467 ohms = 158 *F - 70 *C
332 ohms = 176 *F - 80 *C
241 ohms = 194 *F - 90 *C
177 ohms = 212 *F - 100 *C
132 ohms = 230 *F - 110 *C
100 ohms = 248 *F - 120 *C
77 ohms = 266 *F - 130 *C
60 ohms = 284 *F - 140 *C
47 ohms = 302 *F - 150 *C
