supercharged LT1 tuning help
Old May 13, 2009 | 12:27 PM
1toofastlt1's Avatar
Default supercharged LT1 tuning help
I have a 1997 z28 that im going to tune myself. i have jet DST to tune it with but i have never tuned a car before so im a total noob. i want a really safe tune. i will be running 5-7 psi without a intercooler on a stock motor. what kind of timing should i start with and AF? any info you have will help also. thanks
Old May 13, 2009 | 12:28 PM
i will also be using proscan for my data logging.
Old May 14, 2009 | 07:56 AM
moehorsepower's Avatar
Glad to hear that you want to try and tune yourself, but starting on a boosted application is much more risky than NA. Make sure you have a wideband for logging AFR and be very conservative on the timing, Yes you can pop a stock motor with only 5lbs, Believe me, I've seen it....
