motor tune vs nitrous tune
Did you fatten up the PE tables if it is a dry shot? I don't think 7 degrees will make a world of difference but you still may need to take out more.
Also was the timing set to make the best RWHP before? Could have been more then the car was really wanting.
top" prior to falling back & pinging. So you're on
said flat-top and more spark helps none (or little).
Meaning you can play it safe and not lose much.
Nothing wrong with that.
