Another O2 sensor question!?!
Old May 28, 2009 | 12:50 PM
Fun-Formula98's Avatar
Default Another O2 sensor question!?!
Let me see if I can explain this correctly…
I had my car dyno tuned and everything was working great for about two weeks… Then the car started throwing O2 sensor codes… bank one, sensor 1 and 2… bank two, sensor 1 and 2…
I replaced both O2 sensors and the O2 sims in the back.... The light went off for about a week… ((when the light comes on it runs like ****)) When the light came back on I took it back to the place that tuned the car and they told me that the O2 sensor circuit was not responding at all. It wasn’t working at all… So I replaced the sensors one more time and still the same thing…. The place tuning my car eventually deleted the O2 “circuit” or whatever it’s called completely, and tuned it with the mass air sensor only.
Has anyone ever heard of this before, or had their O2 sensors mess up like this?
Old May 28, 2009 | 01:10 PM
1987firechicken's Avatar
Make sure your headers didn't cook the O2 wires. I looked at mine and it was starting to happen but I caught it in time.
Old May 28, 2009 | 02:29 PM
hhhmmmm... i did check them when i replaced them the first time but i didn't even think to look the second time. Thanks! ill let y'all know!
Old May 28, 2009 | 10:55 PM
Nope... No cooked wires on the headers....
Old May 29, 2009 | 03:26 AM
Sid447's Avatar
Probably,
With the amount of modifications done to the engine it will be difficult for it to run in full closed loop anyway!
One thing you could try is to set the switching point for the O2's from the stock setting (?) to 550mv all the way across the table.
(You'll need tuning software to enable this).
Old May 31, 2009 | 02:17 PM
^^^---- Yeah I'm lost.....What?
Old May 31, 2009 | 03:04 PM
Sam88Gta1's Avatar
Originally Posted by Sid447
Probably,
It can run in Closed loop just fine if its tuned correctly. Changing the switching points to 550mv is a bad idea.If the 02's are bad the pcm will never know it and wouldnt control the fuel like it needs to.
You can try plugging the front 02's into the rear o2 sensor plugs and changing the pinouts at the pcm on the blue connector. You have to swap 4 of the tan wires and 4 of the purple wires around.
Old Jun 1, 2009 | 02:13 AM
Sid447's Avatar
Smile
Originally Posted by Sam88Gta1
......If the 02's are bad the pcm will never know it and wouldnt control the fuel like it needs to.
Okay, seems like you've got it all covered here. I'll butt out.
