New to EFI Live Tuner need some help plz!
so i just got my EFI LIVE now need help on finding where the stuff is i need to change. its a 99 camaro z28 auto need to figure out where to change gears converter rear o2 delete and lower thermostat temp. And is there any other hidden changes that i can do to get more out of it from the stock tune?
thanks!
thanks!
Gears: H0101
Converter: http://forum.efilive.com/showthread....trans+tutorial
O2's: C6001, C6002
Thermostat: system -> fans
You can make plenty of changes for better overall performance, read up on EFI live's forum and here for starters. Typically you can lean it out a bit in PE mode and play with the timing to gain a few HP. But be careful.
O2's: C6001, C6002
