Need to pass inspection in Texas
Went in for an inspection today with my vehicle, just moved to Texas. I had a check engine light for a clutch sensor or something, so i cleared the code before I went in. It came back with 3 not ready's. Evap not ready, O2 sensr not ready, and O2 htr not ready.
I have deleted my O2's Front and rear (running full OL Speed density), I'm wondering once my vehicle reactives all of my monitors if I should pass. I have NO O2's hooked up, and I don't want to fail again when I go back in to get reinspected. Its a 2001 Pontiac. I'm not completely sure if the O2's are "tuned" out, so if anyone can check and see, that would be great. I just need to know what i need to do to pass, so I can get my vehicle inspected!
Thanks!
2 not ready for 1996-2000 cars/trucks.
All Monitor Drive Trace:
Pre-Conditioning Requirements:
- MIL must be off.
- ECT less than 120 F (50 C).
Driving Procedure
- Start with A/C and rear defrost on, idle 2 minutes in drive.
- Turn off accessories.
- Accelerate @ 1/2 throttle, to 55 mph, steady cruise for 3 minutes.
- Decelerate to 20 mph (clutch out, no brake).
- Accelerate at 3/4 throttle to 60 mph, steady cruise for 5 minutes.
- Decelerate with no brake.
I appreciate the information, but its not helping, what i need to know is:
If I have NO O2's hooked up, will the "readiness" monitors be set, or will they ALWAYS read "not ready"?
Thanks a bunch.
Also, here in WI, you are allowed to have 2 monitors not ready until model year 2000, after that you are only allowed 1 not set!!!
Hope this helps!!!
Mike
So, I set everything related to O2 stuff to Not reported, but MIL. So, this means that the "processor enabler" is set to "not reported" so its assuming its good to go, and then MIL active shows its "ready"? Thing is, all of my EVAP was set to "not reported" but all the MIL's still active, and it still showed up as "Not ready" during the inspection.
Good luck!!
Mike
