VE Tuning for S/C, confused????
). My friend just got a D-1SC kit for his 2001 Z06, and we're going to be installing it within the next week or so. My main concern is that once we install the S/C, the VE tables are going to change a ton right? I mean, since the S/C will put it way over 100% VE, how the heck are we going to get this to run perfectly, or should I not even worry about the VE stuff?
). My friend just got a D-1SC kit for his 2001 Z06, and we're going to be installing it within the next week or so. My main concern is that once we install the S/C, the VE tables are going to change a ton right? I mean, since the S/C will put it way over 100% VE, how the heck are we going to get this to run perfectly, or should I not even worry about the VE stuff?joel
The supercharger may still effect your VE even when not in boost though - that would be just like the normal VE tuning outlined previously - you would just need to cut out all values at 105kpa since they will be a jumble of all different values.
But honestly you can get it to run well without touching the VE tables - they will help, no doubt, but it will not be the difference between bad and good, etc. I would get everything running/working normally first, and then you can go back and tweak the VE tables and see if it helps or not.
