Rich after Cam Swap
Tuning is new to me and I have a pro doing it on a dyno next week but here what I need. I have EFI Live and a wideband. The car is running well crappy with the IAT plug unplugged it runs best I can actually rev it some. With the IAT plug out it will barely idle and any throttle chokes it out. I want to get this sorted out before I drive it to the dyno. Anyone have an ideas.
EFI Live say the commanded Air/Fuel Ratio is less 1:1. Once it gets in the 2-3K RPM range it runs smoother but still way rich. I do not have my wideband on yet but will work on that.
I didn't expect the new cam to throw it off this much anything I can do to help with little tuning knowledge.
That issue aside which really wasn't related to the tune it does the following
-idle is OK could be better
-hesitation upon advancing throttle from idle requires feathering
-some backfire evident bringing the rpms down
Here is the efilive scan log file. At the 400 frame mark I brought the power up slightly. Let me know if I should monitor something else.
Thanks
