Engine Shuts Off at idle when hot.
Old Jun 17, 2009 | 01:11 PM
NXZ28's Avatar
Default Engine Shuts Off at idle when hot.
I have a 2000 Pontiac Firehawk with a LY6 (Iron LS3) conversion. Recently it has been shutting off after the motor warms up and you let it idle. If I try to give it gas it sounds like it is flooding. Then yesterday I drove it home from work and it was noticeably bogging in the lower rpms. It almost feels like it has an old quadrajet carb on it. When you floor it, it will bog just a little and then come alive. I can't seem to figure it out. I checked the plugs and plug wires. I only does it when it is hot though. When the engine is cold it idles and runs fine. I was leaning towards the MAF being dirty or bad. The computer is not setting any codes either. Any ideas out there?
Old Jul 6, 2009 | 06:31 PM
NXZ28's Avatar
It ended up being the fuel pump. 36psi running is not going to cut it. It is a Walbro 255 that was installed in the summer of 2004.
