gears, tuning question.
Old Jun 24, 2009 | 06:30 PM
383lt1impala's Avatar
Default gears, tuning question.
Hello all my impala project isn't to far from comlpetion and the rear end is the only thing that's going to cost a lot for it to be complete. My question is can I dyno tune the car with the stock 3.08 gears then later add on the 4.56s I have. Or do I have to get it retuned?
Old Jun 24, 2009 | 07:52 PM
aknovaman's Avatar
Dyno tune will do little other than your WOT AFR and spark tables at WOT.
Get a good street tune in the car as is, then just have the trans, rev limiter, shift settings re-done after the rear is done.
Any resonable tuner will not double charge you for a gear change (long as it's been a reasonable amount of time).
BTW
Check your PM's.
Old Jun 24, 2009 | 08:28 PM
Ohh ok I c. Well its a th400 so. There's no trans tuning needed.
