WOT O2 Question
Old Jul 7, 2009 | 01:12 PM
  #61
Texas_WS6's Avatar
Also when you are doing the balance test it will not let you if you are currently scanning or have a scanned log up. It will tell you what to do.
Old Jul 7, 2009 | 01:27 PM
  #62
Mike454SS's Avatar
Yes, using the scanner to disable closed loop and then also using it to reset the fuel trims will indeed be just like flashing it with a tune that has closed loop disabled.
A-Dub, you're correct, on the window with the cylinder balance test, it will display the results, and as Texas WS6 said, you can't be actively scanning, just click connect, then take over the IAC and begin the test. I think it might require that you wait for the engine to be at operating temperature before beginning the test, but if it doesn't, I would wait anyways.
Old Jul 10, 2009 | 04:25 PM
  #63
A-Dub's Avatar
UPDATE
So I pulled all the plugs, plug wires, rockers, and pushrods to inspect for issues. Found nothing and put the car back together. Did a balance test and lowest was #1 cyl at 92% and highest was #8 at 96%.
Idle, off idle, and part throttle are all operating great, no issue whatsoever. WOT prob is now worse than ever. I forced the car into OL and reset trims and tried to scan a WOT run, but it was misfiring hard, so I got out of it quick.
I don't think its leaning out. Its not a constant lean popping sort of problem. The car is misfiring hard, but only under WOT regardless of rpm.
Any tips on checking for clogged CAT? Car still has the post CAT O2s installed and reading.
File Type: hpl
Old Jul 10, 2009 | 09:36 PM
  #64
Texas_WS6's Avatar
Maybe a week coil. Does anyone know how to test the coils? What they should ohm to? I guess you could swap the coil packs and see if it follows. If the valve train is good and the cylinders are good, then it has to be something external like a coil, wiring to the coil, injector, injector wiring. You know the tune is not the problem, and you say it is not leaning out as if from a bad MAF sensor, so it has to be in the ignition system or fuel system, but only on one cylinder.
Old Jul 10, 2009 | 10:16 PM
  #65
JonCR96Z's Avatar
The correct method for checking WOT fueling on the plugs would be to make a WOT run and shut the car off immediately after you close the throttle. Then pull the plugs (keeping track of which cylinder is which) and cut the threads off and compare the fuel rings on all the plugs. Driving it around and letting it idle (where fueling is fine) will hide the problem as far as the plug is concerned.
Old Jul 11, 2009 | 07:36 AM
  #66
A-Dub's Avatar
The more I thought about it, the more I think its an injector. There isn't anything about the coil that changes with WOT. If it only did it at high RPMs, I might think it was the coil, but its not RPM dependent, only WOT. I'm going to pull and inspect the injectors
Old Jul 11, 2009 | 10:58 AM
  #67
JonCR96Z's Avatar
Is there some one local that you can just swap rails with real quick?
Old Jul 11, 2009 | 01:19 PM
  #68
A-Dub's Avatar
Maybe later this week, my buddy is offshore
 Michael S. Palmer
Old Jul 11, 2009 | 10:15 PM
  #69
jetblast's Avatar
if any one cat was clogged or no longer efficient enough, you would get a related code. but you can get an idea of how efficient the cat is by comparing activity between the front and rear o2s, the more efficient a cat is the less activity rear 02 will show. personally i think if it was in fact a faulty/intermittent coil you would not go lean, due to the fact that during the cycle that the coil fails there is no combustion and so excess fuel makes it to the 02s. i have gone real rich at wot [10 -9 afr] and the car will just bog and sputter.
Old Jul 11, 2009 | 10:30 PM
  #70
Frost's Avatar
Originally Posted by jetblast
,,,personally i think if it was in fact a faulty/intermittent coil you would not go lean, due to the fact that during the cycle that the coil fails there is no combustion and so excess fuel makes it to the 02s....
The O2s don't read fuel, they just read oxygen. An unburned charge pumped out of an exhaust valve looks just like fresh air to an O2 sensor (lean). None of the oxygen was used since no combustion took place.
Old Jul 12, 2009 | 09:27 AM
  #71
A-Dub's Avatar
Well I still can't understand why a bad coil pack only shows itself at WOT, but thats the problem. Swapped coil pack rails from bank to bank and as you can see in the scan, the problem has moved to bank 2. Now I just have to find out which coil pack is bad.
File Type: hpl
Old Jul 12, 2009 | 09:44 AM
  #72
jetblast's Avatar
that makes sense then, at lower loads the spark is strong enough but not at higher loads. evidenced by the swap. thank you for correcting me. it's unusual he didn't get a misfire code.
Old Jul 12, 2009 | 01:11 PM
  #73
Texas_WS6's Avatar
Glad to see you found it.
Old Jul 12, 2009 | 06:25 PM
  #74
A-Dub's Avatar
Found the bad coil and replaced it. Problem solved
Old Jul 12, 2009 | 10:47 PM
  #75
Texas_WS6's Avatar
Great man, glad to see the problem fixed.
Old Jul 13, 2009 | 12:00 AM
  #76
Frost's Avatar
SO does it FEEL like you found that lost 35-40hp?
Old Jul 13, 2009 | 07:44 AM
  #77
A-Dub's Avatar
It "feels" peppier at part throttle. Of course it made a difference at WOT. Easy to notice when its not backfiring
Old Jul 13, 2009 | 07:46 AM
  #78
Frost's Avatar
If you goto the track down here you think of backfiring as an integral part of import racing
I'm glad you got it sorted out.
