Is MAF-T compatible with GMAF??
Old Nov 14, 2003 | 01:54 AM
4thGENRETARD's Avatar
Question Is MAF-T compatible with GMAF??
I'm running Gmaf and MAFT. Is Granatelli allowing for Maft input and flashing?
Old Nov 14, 2003 | 08:25 AM
jimmyblue's Avatar
Moderator
You can put the MAFT behind any MAF that would
hook up to your car on its own. If you set the rotary
switches to zero, it's totally neutral. If you were going
to "flash" (tuning programming?) you might as well take
the MAFT out (or zero it) for that, no point in tuning
for that extra bit of kludge because then you'll be
depending on unnecessary hardware to run right from
then on.
