Fuel Trims Question
Old Jul 6, 2009 | 01:23 AM
RevGTO's Avatar
Pontiacerator
Default Fuel Trims Question
Do long term fuel trims function on the basis of O2 sensor feedback alone, or do other calculations figure into the equation? Example: Commanded AFR/IAT/ECT result in fuel trimming?
I'm working on my OLMAF tune and wondering if I should have disabled LTFTs.
Thanks for any help ...
Old Jul 6, 2009 | 05:53 AM
macca_779's Avatar
Hell yes you should disable LTFT's.
LTFT's are built off STFT averages and then stored for permanent reference. If you don't zero them prior to trying to dial in a MAF or VE. The stored values are still effecting primary fuelling.
Old Jul 6, 2009 | 08:14 AM
ringram's Avatar
Best to disable LTFT IMO anyway,
They are evil and will come back to rape you sooner or later.
Old Jul 6, 2009 | 09:28 PM
RevGTO's Avatar
Pontiacerator
Well, yes, I disabled them when I went full time open loop and ditched my O2 sensors. Just wondering if they were supposed to function even without the O2 sensors.
Thanks guys.
Old Dec 18, 2010 | 01:22 PM
Pavetim's Avatar
so you can leave your LTFT disabled and it won't hurt anything? Will it still correct for altitude and baro changes with LTFT disabled?
Old Dec 18, 2010 | 02:39 PM
macca_779's Avatar
Yes. LTFT's are only there to correct for errors. If there are none then they are useless.
Old Dec 18, 2010 | 03:04 PM
Pavetim's Avatar
But what do you mean by errors? Errors in the tune or errors in say if you drive from florida to colorado?
Old Dec 18, 2010 | 03:33 PM
Mez's Avatar
Mez
Error vs. commanded a/f ratio in your tune.
Old Dec 18, 2010 | 06:06 PM
macca_779's Avatar
Tune mate
Old Dec 18, 2010 | 06:51 PM
disc0monkey's Avatar
Originally Posted by macca_779
Tune mate
huh ?
Old Dec 19, 2010 | 12:35 AM
tording99Z28's Avatar
Errors in your tune. If your tune is spot on and your STFT's are very close to 0 then the LTFT's do nothing and therefore could be left off is what they are saying.
Old Dec 21, 2010 | 03:14 AM
LS1C5Vette's Avatar
Full time OL huh? Stay on your tune. Not something I would ever do.
Old Dec 21, 2010 | 07:26 AM
Frost's Avatar
not full time OL, just no LTFTs. STFTs will keep things in check once the car is tuned.
Old Jan 5, 2011 | 05:20 AM
LS1C5Vette's Avatar
Dammit, I read the 1st post wrong. I agree tho, shut off LTFT.
