need help please, sorry long read
let me start with the car, 99Z M6, stock bottom end with head and cam pkg with bolt ons and spray. i could be more detailed if someone thinks it will help. car is currently tuned SD. a few weeks ago the car thre 4 check engine lights, 2 for o2's, a MAF (because it was deleted) and one for MAP, i forget if it was low or high voltage, it was the one that would lead some to think a vacuum leak. Took the car back to the tuner and they worked on it, turned out all they could find was a few bad plug wires. they dynoed the car again and all was good, i even drove it 3 hours each way to Carlisle PA. got 26 on the hwy and tore apart a mustang on the hwy. a few weeks ago the car started idling bad and running poorly. the car will barely idle, like around 500 then after a few minutes jump to like 2K until i kick it down like and old carb car. and it has no *****. took it back again, no check engine light, all they could find was a lazy O2 so they put me in open loop. the car runs and drives now but IMO feels like crap. it runs rough, especially mid range, no ***** still to me and even had the same idle issue yesterday. i sprayed it on the hwy last night from a 75mph roll against a friend in his stock cobalt SS and the car pulled but not as hard as i expected. it feels like there is something missing. please guys, any input would be great.
