Whats the difference betwen High Octane and Base spark in gear??
Restricted User
Ok , need to make it so max timing advance is only going to be 25* whats the suggested way to do this? And whats the difference of Base spark in gear and hi octane table?
Thanks
Charlie.
Thanks
Charlie.
Thanks
Charlie.
Thanks
Charlie.
+ Base Spark In Drive - Closed throttle, in gear timing advance table. Non-Load . Referenced by non-load cells 17, 19, 20, 21.
+There are timing tables we don't see it Edit.
+I guess set max timing at RPMs to 25 in High and Low Octane tables ( They are actually blended, depending on recent knock history, by the PCM). Might also Edit" Max Brake Torque" table also ...not sure if and when it's referenced.
FWIW
joel
Restricted User
Joel,
- whats the method of selecting the rom vs. g/sec in high octane table?
- so for timing while idling in gear it would be the base spark in drive?
Thanks, this seems more confusing. With every part I get deeper into it.
Charlie
Charlie
Joel,
Charlie
Charlie
Charlie-
Yes, idle in gear would be Base Spark in Drive.
It's RPM vs gms per Cylinder. Grams per Cylinder = [MAF (gms/sec) * 15] / RPM.
I'm not really sure what your first question is/was???
joel
Restricted User
oh, the 1st one, is in the hogh octane table, it has top row of RPM, and the side column of g/cyl and was trying to find out, the ways to adjust it, liek is it better to only mess with a certian area of the table based form the g/cyl and or RPM, or blanket the whole table?
joel
