Can't reset codes
Old Aug 14, 2009 | 08:18 PM
cacmanjr's Avatar
Default Can't reset codes
The MIL light on my ls1 to 66 Buick swap is on. I connected a buddy's cheapo OBDII scanner to it and saw 2 codes. I tried to reset them following the instructions with the scanner but they would not reset. Any idea what the problem could be?
Old Aug 14, 2009 | 08:46 PM
69LT1Bird's Avatar
What codes? If they come back on, they either have not been disabled in the computer or you have a problem.
Old Aug 14, 2009 | 09:34 PM
cacmanjr's Avatar
I don't remember the code numbers but it was a problem with the ecm/engine misfire. The codes didn't return, I was not able to reset them. Once I get the fuel pump sorted out, I will scan it again.
Old Aug 19, 2009 | 06:59 PM
cacmanjr's Avatar
OK. I re-scanned the car today. There were 2 P0121 codes which are something to do with the throttle position sensor, 1 P0155 which is oxygen sensor heater circuit malfunction bank 2 sensor 1, 1 P0480 which is cooling fan 1 control circuit malfunction and 2 P1336 codes which are crankshaft position not learned. The P1336 codes are the ones that will not reset. If the computer does not know where the crank is, what problems will it cause in engine operation? Thanks for all the help already provided. This thing would not be running at all without you guys.
Old Aug 19, 2009 | 07:04 PM
eseibel67's Avatar
You need to de a CASE relearn. Only takes a minute, but you will need a better scanner that has this capability.
Old Aug 19, 2009 | 08:13 PM
jimmyblue's Avatar
Moderator
Crank learn takes a minute when you finally get it
to go. But I've spent tens of minutes trying to
push the gas pedal just-so, just-when. PITFA.
Fortunately it doesn't need done, except when
you swap the PCM or similarly mess around.
Old Aug 19, 2009 | 08:49 PM
cacmanjr's Avatar
From what I have read of crank re-learns, a conversion will probably not have the needed switches to do it. If I remember correctly, you have to hold the brake pedal down while the re-learn takes place. My 66 Buick does not have the necessary switch on the brake pedal.
