PCM Red Connector Pin 10 Help
Where would that white wire be connected to? switched 12v at the relays, BCM, PIM. I traced pin 10 to an unknown connector. See the quick illustration to better understand. Any help is appreciated.
I hope that helps
ms
WTF Desert Racing.. I read another thread you have and I was wondering if you have a clutch or neutral safety switch connected. PCM will not start if it is not detected.
That is a good idea to check. I really have nothing else to go on at this point. The PCM program should be for an automatic (motor is mated to a TH400) so no input is needed, but worth checking to see if the PCM is expecting a signal from the clutch safety switch. I cant wait to get home and check it out!
