different wideband readings
Old Aug 19, 2009 | 05:20 PM
adam1803's Avatar
Default different wideband readings
On the dyno my car was tuned to ~12.8 a/f. I installed a PLX wideband last week and have noticed that under WOT its reading ~13.5-14.0 on the street. Is it common to see this?
Old Aug 19, 2009 | 08:10 PM
jimmyblue's Avatar
Moderator
It's common for AFR to be lean in lower gears because
the actual air is always "ahead" of the measurement
that drives fueling. Dyno is in higher gear and maybe
a slower run-up in RPM.
There's also a lot of potential for discrepant instruments,
especially if you have a ground offset problem as many
"hobby" widebands do (anything where cig lighter is the
-assumed- reference ground, will be skewed by some
amount while a self-powered wideband that's independent
of the vehicle electrical system, should not).
Old Aug 19, 2009 | 08:16 PM
adam1803's Avatar
Hmm, i've got it wired to the rear defrost switch since i never use it. I guess maybe i should try wiring it differently.
